SSC and HIC
SSC and HIC
For one of Sour service pump the process data sheet specifies that the material shall meet MR0103 and HIC. Also it specifies the MOC shall be SS316. From Nace Mr0103 , we can understand that the Austenitic stainless steel materials are comply with MR0103. But what about HIC? Whether all the Austenitic stainless steel meet HIC requirements?
If an Austenitic Stainless steel meet the MR0103 requirement whether the material is suitable for HIC also?
Thanks to clarify.
Thanks to clarify.
RE: SSC and HIC
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
RE: SSC and HIC
HIC resistant material requirement it is only applicable to carbon steel. Mainly it's related to the maximum value of sulfur content of the steel. A good carbon steel resistant to HIC must have a sulfur content inferior to 0.002%wt.
Ricardo Costa
RE: SSC and HIC
While the limit mentioned by rscosta is commonly used for carbon steel plate (that's the number I use myself) higher limits are used for other product forms like seamless pipe, forgings and castings. These limits are discussed in NACE/ISO.
RE: SSC and HIC
RE: SSC and HIC
