Print to File in NX4
I would loke to create an HPGL file and It's not possible to store the switch "Print to file" in the system profile. we have to press it for each plot.
I found on uganswer that it's possible to use the option Render file the execute programm but I didn't find the solution.
Thanks in advance
Didier Psaltopoulos
www.psi-cad.com
RE: Print to File in NX4
define a hpgl plotter use render and execute option in the definition and use the attached bat file
Thanks a lot, It works very well
Didier
Didier Psaltopoulos
www.psi-cad.com
