Unloading noise in screw compressor..
Dear All
I was referred an abnormal noise arising out of a motor driven screw compressor (4 lobe compressors) during unloading. Typically these compressors run at the same speed (1450 rpm in this case) for loading and unloading conditions. The operating pressure of these compressor under loading is 7 bar. I could see the 8th harmonic (spectra of sound pressure as attached)picking up in unloading. The operational excitation frequencies: Motor speed=1450rpm, Screw meshing freq=96.7Hz & its harmonics and the responses corresponds to them.
I was wondering why this 8th harmonic ( a couple of others as well) is picking up in unloading condition. The speed in both loading & unloading are the same, barring the slip at unloading condition.
Kindly provide your thoughts on this.
Thanks in advance
Jeyaselvan
Thanks in advance
Jeyaselvan
RE: Unloading noise in screw compressor..
You are very right, this is an oil flooded screw compressor. The intake valve has a bypass(with a check valve), but usually it was sized to ensure a minimum sump pressure of say 2 to 2.5 bar to ensure adequate lubrication under no load condition.
I am just wondering why the noise levels are very high(but all are typically harmonics of screw meshing frequency). the noise sounds like a booming vacuum noise. I have attached same for your reference.
Jeyaselvan
I was wondering what could happen, if the suction is completely closed. How would the bearings get enough lubrication without the pressure, since quite often in oil flooded machines, it is the pressure induced lubrication?
I understand the load on the bearings is lesser during unload as well, but still?
Jeyaselvan
