Where is "Bolt Circle" listed as BC in the ASME 14.5 spec.?
thread1103-191028: DIMENSIONING
I'm trying to find the exact reference as to how a bolt circle is to be called out per the ASME 14.5 Spec.
If it is listed as "BC" or "BCD" (which is redundant) then where do I reference the exact callout? I can only find examples that list: places, Diameter symbol, dimension of the diameter, then the words "BOLT CIRCLE".
I have seen this as a standard practice on drawings as: places, diameter symbol, dimension of the diameter, then BCD or just BC.
Which is the proper (meaning by Spec.) callout for the bolt circle on a drawing?
RE: Where is "Bolt Circle" listed as BC in the ASME 14.5 spec.?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
