Windows Explorer File Manager not showing...
This is happening with my Civil 3D 2008.
Suddenly, the Windows Explorer File Manager window (you know, the window that appears when you select "open" or "save" in the Civil 3D menu -- where you select the file you want to open or the folder you want to save your file in) is not showing anymore, forcing me to type the complete path to the file or folder in the C3D command line.
I uninstalled and reinstalled C3D and the problem persists.
Any idea on how can I fix this?
Thanks.
RGuerra
Thanks.
RGuerra
RE: Windows Explorer File Manager not showing...
____________________
Civil 3D 2008, Terramodel
RGuerra
