Underlining overriden dimensions in drafting
I wondering if there is any way of automatically underlining any dimension in drafting that has been overridden. I would like to see a checkbox included in either Tools > Options > System Options > Drawings> OR Tools > Options > Document Properties > Dimensions so that one can choose to automatically underline all dimensions that have been overridden in the drafting application.
The glass is operating at 50% capacity.
RE: Underlining overriden dimensions in drafting
What would the underline tell the machinist or inspection?
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
-handleman, CSWP (The new, easy test)
It would tell them that the dimension is not to scale, per ASME Y14.5.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Curious what ubercad's company definition of it is.
CBL,
That would be a pint of blood.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
In the 15 years I have been working there have always been those who, due to ignorance, laziness or apathy, have decided to take the easy way and cheat by overriding the dimension thereby creating an inconsistency between the drawing and the 3D model. This has undoubtedly cost many businesses a great deal of money when one part doesn't fit with another. In some very rare instances it may be necessary to override a dimension, but this ability has definitely been abused, and at great costs.
I would like to see Solidworks (as well as other 3D CAD software's) make it a mandatory function that ALL overridden dimensions be underlined.
Just make the model work, retrain users to make it right or find another job.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
I cleaned up once after an idiot who exploded dimensions in AutoCAD and retyped the dimension text. I met another mechanical designer who fantasized about what he would like to do to people who did stuff like this. Either we encountered the same guy, or there is a group who believes in this.
If they do this in SolidWorks, your whole solid modeling process is dead. You might as well uninstall SolidWorks, and buy everyone a box of crayons.
You cannot inject blood into the SolidWorks file. Perhaps the HOWTO books on SolidWorks should be bound in sharpened steel covers so that they can be used as weapons.
To the critics of this practice, there may be something that wasn't modelled correctly because of limitations of the software. This isn't as common these days since SolidWorks can handle most shapes...but it was an issue 10 years ago.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
