Wrong Stamping
Wrong Stamping
I had the stamping done on a header with low stress stamps and the year built is wrong. Should have been 2009 not 2010. Is it ok to sand off the 10 and replace it with 09? I cannot find anything on removal of stamping under ASME section 1.
RE: Wrong Stamping
RE: Wrong Stamping
I suggest you ask your Authorized Inspector for the proper procedure.
RE: Wrong Stamping
At your AI discretion, you may cross out the whole stamp and restamp it fresh or cross the incorrect year and restamp the correct year. I don't believe the later would be acceptable modification, though (not controlled).
Cheers,
gr2vessels
