NFPA 850 codes
NFPA 850 codes
NFPA 850 codes
Hi there,
We are in the power plant construction industry and have to follow NFPA Codes and standards in addition to the relevant ASME Codes. I am looking for information on NFPA 850 which is related to fire protection in power generating stations.
I would like to know if the fire tanks, pumps etc. are to be sized in accordance to this standard.
Can somebody share a pdf file of the same or direct me to where i can review this?
RE: NFPA 850 codes
You might also want to look at forum184: NFPA (fire) Code Issues.
However, if you're designing systems that need to meet NFPA805, then I totally agree with TGS4 -- you need to have a copy.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
