heat treating 17-4 ph
Does anyone know the tempering temperature to heat treat 17-4 ph stainless to 50+ Rc?
I know this is really hard, but water is going through it at about 15,000 psi..
any help would be appreciated,
thanks,
brent
RE: heat treating 17-4 ph
Rc 50 is in excess of the normal hardness attainable for
17-4.
Pressure containing systems should be designed based on tensile and yield strength and not for hardness.
brents,
I agree with israelkk: You should not be designing for hardness in a pressurized system.  However, I would guess that you are using a conversion chart & desire to have a tensile strength around 250 ksi, based on your desired Rc50.  If so, you won't get there with 17-4 PH (according to Mil-Hdbk-5).  H900 Condition is 170ksi yield, 190ksi ultimate.
PH13-8Mo will get you a little higher; "Custom 465 Stainless" will go even higher.  Need to look at the whole picture, though - ductility might be a different requirement.
Pete
Custom 465 is nice stuff, if you can find it, and if you can figure out how to connect to it.
Plymouth Tube
