Search the coordinate systems?
Where are the coordinate systems in the master part of these two parts?? 0004991 is master and 0004991-110-01 is the specification.  I can't select/make visible the coordinate systems in the master?
I tried visible in view / switching of timestamp and search for unused items / All layers visible / ...
I use NX4.
Thanks in advance.
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
RE: Search the coordinate systems?
In 0004991, you need to Unblank/Show All.
then in 0004991-110-01, either set the Reference Set to be Entire Part, or add the coordinate systems to the Solid Reference Set.
Specialty Engineered Automation (SEA)
http://www.sea4ug.com
a UGS Foundation Partner
Thank you Philip it was right under my nose and i could'nt see it. smile
Best regards,
Michäël.
Belgium
