Shear Wall with openings
I am searching for a design example of Shear walls with opening in net but all i found was a design example used in Wood shear walls
anyone of you have example for reinforced shear walls with opening?
pls? thanks
pls? thanks
Poems are made by fools like me, but only God can make a tree. engineers creates wonderful buildings, but only God can creates wonderful minds
RE: Shear Wall with openings
Best to visit your local university to acess these books because of copyright reasons.
thread726-253725: Shear Wall Openings
on of the panels have two or more openings due to doors and windows
my recent analysis is only for shear walls that is not tilt up so its easy to analyze one portion of it as a whole shear wall then the upper wall of windows or door is analyzed as lintel. But what happened if this will be a tilt up wall that can be consider as a whole shear wall that with opening?
i know that shear walls with opening can be found on IBC 2305.3.8 but I still needs an example problem for this
thank you in advance
