Assigning Modulus
Assigning Modulus
Assigning Modulus
I have a model of a structure which should have a Young's Modulus that is different when in tension than in compression.  In essence, I have to assign 2 modulus values to the same model elements, and which modulus used depends on whether the model is experiencing compression or tension.  Could anyone offer any suggestions as to how one commonly approaches this situation?
Thank you,
Gill
RE: Assigning Modulus
I have a model that has is under two different load codition  (i.e, force and pressure), these loads are applied during the same priod of time but one of them is stepped load while the other is ramped.Could anyone offer any suggestions as to how one commonly approaches this situation in ANSYS?
 R. Adibi Asl
