Dynamic Edit Visual Dimensions
Hi All
Does anyone have problems with visual dimensions while using dynamic edit? This example (see attached PDF) is in ST2 traditional
As you can seen the dimensions are unreadable
Is there setting I'm missing
This wasn't an issue while using V20, my setup and system are identical as V20
Using ST2 MP2
Intel Core i7 cpu 920 @2.67GHz with 3GB ram and a FX1700 card
Using ST2 MP2
RE: Dynamic Edit Visual Dimensions
How about increasing the text size.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Thanks, I tried that and also changing the font.
This helps and is marginally better on new parts, but existing parts hold their orginal setting and its tiresome to change for every part.
Is there a global setting that forces the change to every file opened regardless of prevoius settings.
Cheers
tony
If you wish to have a standard size on your dimensions different than default you can also set up a template using a new named part file, or any other type, that would reference this change and after saving it it becomes available in your template list for future use. Personally I find this is just a matter of clicking on the increase/decrease size icons and have never set up a seperate template to do so.
I believe that these user specific templates can also be moved from a current version to a new one or another PC by a simple copy and paste to your templates file in the SE template library.
