Top layer or reinforcement in column footings
What is the top layer of steel for in a reinforced concrete spread footing?
I have seen multiple structural designs where some engineers specify a layer of steel at top and bottom of footings and others where engineers only specify the bottom of the footing.
The only two reasons I see it being necessary is either for uplift changing the direction of bending in a footing or temperature and shrinkage min. steel requirements. Just looking for some guidance. Thanks.
RE: Top layer or reinforcement in column footings
After posting I read in the RISAfoundation manual that their program will use a top layer when the footing goes into "partial uplift" designed for the negative moment induced by the uplift action.
It seems to me that for simplicity, a lot of engineers just place whatever amount of steel used in the bottom (based on design) in the top of the footing also. Just wanted to make sure I wasnt missing something. Thanks for the responses.
If is is smaller bars, then it could be minimum reinforcing or for uplift.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Never, but never question engineer's judgment
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
_|___|_____
\o_o/
Can you explain your above comment with regard to consolidation?
http://w
With top bars in deep sections, it is usually necessary to revibrate to prevent plastic settlement cracks.
Those settlement cracks illustrated in the link due to different thickness are a worse situation than the ones over the bars.
I have never seen it. Makes good sense and it is good to know.
Our guys do run vibrators in the footing during the whole placement. Maybe we're getting lucky?
