Position,Velocity,Acceleration!!
I have a problem here.Suppose a particle starts from the origin , x=0, with no velovity but with a positive acceleration.Under this acceleration the particle gains a positive velocity and moves in a positive direction.Can anyone explain this physically.
I am not able to physically imagine a particle with zero velocity(rate of change of displacement) and positive accleration(rate of change of velocity)
RE: Position,Velocity,Acceleration!!
so velocity=ds/dt=(2-0)/(2-0)=1cm./sec.
This is at the end of 2 secs.Can u explain like this with regard to acceleration?Please
If acceleration is constant,
Acceleration at time t A(t) = Ao
Velocity at time t V(t) = Ao *t + Vo
Position at time t X(t) = (Ao*t^2)/2 + Vo*t + Xo
For your example:
Initial acceleration Ao = gravity = 9.81 m/s^2, initial velocity Vo = 0, & initial position Xo = 0
V(2) = 9.81*2 + 0 = 19.62 m/s & X(2) = (9.81*2^2)/2 + 0*2 + 0 = 19.62 m
V(3) = 9.81*3 + 0 = 29.43 m/s & X(3) = (9.81*3^2)/2 + 0*3 + 0 = 44.15 m
V(4) = 9.81*4 + 0 = 39.24 m/s & X(4) = (9.81*4^2)/2 + 0*4 + 0 = 78.48 m
And so on.
Though I couldn't understand the purpose of this question, I really liked your spirit. (of not bothering about academic vs professional) This attitude does keep this site lively.
Cheers,
Truth: Even the hardest of the problems will have atleast one simple solution. Mine may not be one.
You could put in your thoughts too(in a physical sense) to the question.Thanks very much cause i started feeling a bit down before your comment.
As my Grandad said:
There's no such thing as a stupid question, just stupid answers.
Just about questions:
Your Grandad was a wise person!
I was always feeling uneasy to pose questions till the other day when I saw: Bad question is the one that was not asked.
The force due to gravity has the effect of acceleration on a mass when there is no opposing force on that mass.
A mass in a gravitational field results in a force. This is a concept that man has still not conquered!
It requires force (or net force to be correct) to accelerate a mass.
I always find it entertaining to consider the action of the earth when a mass is released. Every force has an equal and opposite reaction.....when you release a mass and let it fall by gravity, the earth has to move towards it to balance the forces (an immeasurably small amount, mind).
Think about what you just said.
Then go back to Physic 101..........
Remember...
"If you don't use your head, your going to have to use your feet."
