FLANGES WITH CLAMPS
FLANGES WITH CLAMPS
FLANGES WITH CLAMPS
Any suggestions about calculation flanges with clamps to Section VIII Div 1. In this case Bolt Circle is larger that Outside Diameter (?).
RE: FLANGES WITH CLAMPS
The design rules for clamped connections are described in Appendix 24 of ASME VIII, Division 1. While tedious in nature, these rules will permit you to perform custom designs as needed. Unfortunately, some of the data (such as seal retaining loads, seal make-up loads, seal gasket diameter, clamp geometry, etc. are considered proprietary information and the  suppliers are very reluctant to provide it. A more practical approach maybe to provide the design conditions to a vendor and let them perform the design calculations for you. Vendors you can contact include:
LTS Energy - www.ltsusa.com
Grayloc - www.oceaneering.com/subsea-products/grayloc Techlok - www.group-vector.com/clamp-connector
There are others as well.
