Close Current Document Macro
I am working on a macro with some common commands that i can check off and press a button and it applies all the commands with a check.  One command I am having trouble with is the close current document.  I have tried a couple of different variations that I found by searching, but the only one I can get to work (sometimes) is below.  I say sometimes, because it will work once, then it quits for a while.  Does anyone know the correct way to do this?
End If
'Close
If CheckBox4 = True Then
swApp.CloseDoc sFileTitle
Else
End If
End Sub
RE: Close Current Document Macro
Here is the code with the first few lines.  The Set part = activedoc line does that, right?
Private Sub CommandButton15_Click()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
'Close
Else
End If
End Sub
I'll have to try it at work, but I think it's something like:
CODE
swApp.CloseDoc(Part.GetPathName)
In the snippit of code above...I don't see you ever assigning a value to sFileTitle...maybe that's the problem with it? If somewhere else you had a line like:
CODE
sFileTitle = Part.GetPathName
Then your's might work.
Quote:
I'm just a hack though. :)
Then what does that make me?
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
brengine, I think adding the definition is what I needed.  Ill continue to give it heck and see if it works.  Thanks for your help.
Bsj,
That's kinda what I was working towards finding out when I asked to see your code, to make sure my hunch was correct...but brengine just jumped right in! :)  Star
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
