Tin verses SS
4
Tin verses SS
Tin verses SS
I need to put a bunch of springs up against tin soldered pads.  Stainless is being pushed in this regard.  You guys see any issue with this? I suspect it won't be a problem.
Keith Cress
RE: Tin verses SS
I can't see any real issues with this arrangement as presented.  We had some springs on some contact arms that were in contact with Sn-Pb solder and ran for years with no problem.
Here are two minor concerns.
One problem that I envision is that the springs will move a little metal in the landing area.
If this is pure tin there is a small possibility that the tin will oxidize a little in the contact area.
RE: Tin verses SS
The tin will creep under load, that is the springs will impress into them.  there should not be adverse interaction between the two metals.
Plymouth Tube
RE: Tin verses SS
IR that's a god point.  I suspect that those Battery Springs were generally something else and plated but I'm not sure.
fox; Thanks for that table.  It does show some reason for concern... dang!  These joints could have some high humidity associated with them occasionally.  Perhaps I need to consider nickle plated springs.
Keith Cress
RE: Tin verses SS
Hi itsmoked
A possible alternative to plating the springs, would be to introduce an end cap over the spring that eliminates the possible corrosion problem between the stainless and tin.
Although this might cost more than plating, just something to consider.
desertfox
RE: Tin verses SS
Your moisture would have to be fairly conductive in order to get galvanic corrosion issues.
If you are concerned a small plastic shim between the two might be less trouble than platting.
Plymouth Tube
RE: Tin verses SS
The spring has to electrically connect to the tin pad. This is for a touch keyboard.  :)
Keith Cress
RE: Tin verses SS
I wouldn't worry about it.
Plymouth Tube
