how can I add a 1mm coating of aluminum or copper to steel?
The coating is supposed to carry induced electrical currents better than the steel itself. Would be placed on a steel plate 20+mm thick. Due to large magnetic fields and large forces induced by magnetism this must be a mechanically strong coupling. Does anyone know of a process I could use? Thanks.
RE: how can I add a 1mm coating of aluminum or copper to steel?
I'm looking into hot dip aluminizing and it seems promising. Can't find a commercial provider of this service though. Thanks!
I would give both White and Brodeur a call and discuss your specific requirements.
http
http://www.brodeurmachine.com/coatings.htm
I'll look into all ideas, thanks everyone.
Plymouth Tube
