Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...An excellent site which has quite possibly prevented me from having a mental/nervous breakdown..."
Geography
ajc17 (Structural)
8 Feb 10 15:24
I am familiar with applying joint patterns in SAP2000 in typical X Y and Z directions, but have come across the need to apply the pattern radially, starting at the center of a circle and changing as the radius is increased.  Any ideas of how to deal with this would be helpful.  Thanks.
Helpful Member!  osquro (Structural)
8 Feb 10 22:02
First assign any pattern value to the joints.
Then you can use "Interactive database editing".
Export this tables to Excel: "Joint Coordinates" and "Joint pattern assigns".
I guess your model was made using rectangular coordinates, so you should use a function in Excel called "vlookup" in the "Joint pattern assigns" sheet to find rectangular coordinates of each node with a pattern value. Then you can transform rectangular coordinates to polar coordinates using some calculations in Excel. Finally you calculate the desired joint pattern based on the polar coordinates and import the tables to SAP2000.
It is easier than it seems.
I did it a couple of times to apply seismic and wind forces to a liquid containing cilindrcal structure.
Close Box
Join Eng-Tips® Today!
Join Us             Close
