Stresses in a buried pipe
This might more belong to the structure section, but I guess it's quite common in geotechnics.
I want to calculate the stresses induced in a thin-walled buried pipe. I am using the usual formula for the hoop stress (see the link): sigma=P*R/t
Also I'm using the vertical total stress for P, as, for sand and no lateral movement, the horizontal stress is smaller.
Is this method correct or is there a more relevant one?
RE: Stresses in a buried pipe
Example,
http://w
h
http://www.dipra.org/
Richard A. Cornelius, P.E.
WWW.amlinereast.com
To dicksewerrat: I think that hoop stress is indeed, in most cases, a tensile stress due to internal pressure, but the formula to get it still works if the pressure is external (in which case it becomes compressive). See the remarks in the link on my first post
