Getting lot of Intenal errors while loading the assembly
Hi All,
TCE2005SR1 MP6 and NX6.0.2.8 MP6
Getting lot of Internal errors while trying load the assembly. Also Noticed that loading of assemblies takes longer time than NX4.0.4.2 MP10..
Is there any fix for wiping out internal errors? If I load the assembly in NX4, it loads fine and also quicker..
Can some give me some idea of how to handle this..
RE: Getting lot of Intenal errors while loading the assembly
Contact GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Check to make sure your load options are set the best way for you, here is how mine are set:
* File > Options > assembly load options > Load (at top) "as saved"
* Under "scope", check on "use partial loading"
* Under "reference sets" > "as saved" is the first one I have on the list
This will pull up the assembly as it was last saved
Also ... You may want to pull up as assembly in NX4 and see what your setting were, and then save them to a file (I think it was available in NX4), and then "open from file" in NX6 (located at the bottom of the "assembly load options" menu)
