Black oxidation?
Black oxidation?
I am currently working through an ABS/ASC fault on an E39 BMW 528i M-Sport 1999. I have replaced all 4 ABS sensors and had the ABS module refurbished. The lights on the dash came on last year which is the reason I changed all 4 and had the module refurbed. The fault cleared for about 3 months, now the lights are back on. I was out this afternoon and found a small nik in one of the wires on the NSF ABS loom. I trimmed some wire back and noticed it was black, so I trimmed back some more, it seems the wire is black all the way through. I'm a bit nervous about trimming back too much as the loom is short enough as it is. I have never seen a wire turn black before, only green oxidation. Can this cause a high resistance in the circuit? I have tried to solder the blackend wire to a fresh one but the solder will not take to the blackened wire at all. Any tips or ideas?
RE: Black oxidation?
How about the connectors themselves? Clean and bright? I would suggest a light coating of silicone dielectric grease on all connectors and crimps wherever possible.
Are there not codes stored in this system that will point you closer to the problem?
