DMX Controlled AC Dimmer Grounding (Earth and Circuit)
Hi all,
I'm designing a system with one DMX controller and 10 DMX controlled AC dimmer.
Dimmer is triac based one and 300~650W, 230VAC.
All dimmer modules will be encased.
And i want to ground the case to neutral(earth) to prevent problems like ESD and leakage.
Can i tie module's circuit ground to neutral earth ground?
I saw AC dimmers will induce lots of inductance to neutral earth ground.
If this is so, even I tie circuit and earth on single point, I believe, DMX communication will be affected. (since DMX uses GND pin to tie modules together.)
Plus.
I use opto-couplers and isolated, regulated DC/DC convertor for DMX comm. for preventing ground loop.
Thank you in advance for your time and knowledge.
hojun
Plus.
hojun
