relation b/w mechanical i/p, turbine speed & load variation
Turbine speed remains constant at rated speed once the m/c is synchronised....during change in load the governer issues command for opening/closing of nozzle/deflector which means mech. i/p (water/steam)to the turbine is varied accordingly.....however the turbine speed has to remain at rated speed despite the mech. i/p....the question is how does the load(power o/p) vary at constant rated speed???
RE: relation b/w mechanical i/p, turbine speed & load variation
To answer your question: There's more to power than speed alone. There's also torque. When the load increases, the mechanical input to the turbine increases to add more torque.
If you look at the attached generator, you will see a change - not in speed, but in pole angle - and in current, of course.
Power = rotational speed times torque. If rotational speed is constant and power increases, the only factor that can change is the torque. And that is exactly what happens.
Gunnar Englund
www.gke.org
if it is for the governer then how does it regulate...wat i'm confused abt is dat "if we increase the mech i/p then turbine speed will increase & if governer is to take action in maintaining a const. speed it has to ultimately control the mech i/p which means it has to reduce the i/p agn." i hope u understand wat m' tryin to say... hey mind not coz m' very new to this subject n, dont hav mch idea...it would b nice of u to guide meh.... thx
If you are sitting at a computer, I would appreciate if you rephrase your question. And, please, use capital letters, punctuation and no abbreviations. That is how we communicate here.
Also, please redflag your redundant thread with my handle. All you wanted to say is probably included in this thread.
Gunnar Englund
www.gke.org
PS
Hi kixs84;
Skogs speaks several languages fluently including Boolean.
However I don't think that he is fluent in tx. We do our best to overcome the language barriers inherent in an international forum but not many of us older members are NOT comfortable communicating in tx. Can you repost in English with capitalization?
thx
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
Do you have multiple loose connections in your keyboard?
LOL
I don't have many brain cells left. When the few synapse connections that I have left are struggling to decipher tx, I have little capacity left for the problem at hand.
Bill
Bill
"Why not the best?"
Jimmy Carter
Try a search of this site. There are many discussions and explanations of governor action.
Bill
"Why not the best?"
Jimmy Carter
You guys are better lads than I am. About half way through his second post, I gave up and said what the he**. If he/she isn't interested enough to make the question comprehensible, I don't have the time or patience to try to decipher it, even though I did know the answer.
Want to bet this thread will be gone in the morning?
rmw
Gunnar Englund
www.gke.org
well my doubt is, how does the turbine speed remain constant despite increase in mechanical input.
now for your understanding take an example:-
The machine is connected to the grid and i am trying to increase the station load. Now when i issue command for increasing the load, what actually happens is mechanical input(water/steam) to the turbine is increased. So , in this case more force is exerted on the turbine (which is already at rated speed) and will tend to increase the rotational speed.
However, the machine remains at rated speed. now how does this speed remain constant.
There are two main types of generators for alternating current. The synchronous and the asynchronous generator. The synchronous generator has a rotor with magnetic poles that are locked to the grid frequency. It simply cannot move faster (or slower) without tripping.
The other type is asynchronous. That one runs slightly overspeed - and more so the more power the turbine puts into it. The difference between 'grid speed' and generator speed is called slip and is usually in the 1 - 3 percent range.
All large power plant generators are of the synchronous type. Their speed is constant and all that happens when turbine 'pushes harder' is that he pole angle (angle between stator flux and rotor poles) increases.
Smaller plants often use the asynchronous generator. For that type of generator, your assumption about constant speed is not valid. It adapts speed after load.
Gunnar Englund
www.gke.org
so what i understand now is that the change in speed is compensated by change in pole angle which ultimately results in the change in load/power.
now in this regard can you state some relations describing the realation between speed,torque, power and load angle so that i can have a clear understanding.
thx agn.
In a synchronous machine connected to the grids there is no change in speed.
Somewhere on the grid there are one or more large machines that compensate for load changes and variations in distributed generation inputs to keep the frequency and resulting speed constant.
Think of one bell crank driving another by an elastic band between them. One crank is held at a constant speed (by the grid). The force driving the input crank is increased. (Throttle or steam valve opened further.) The elastic bank stretches a little and the angle between the driving and driven cranks increases slightly. In a synchronous alternator the rotor is feeding power to the grid by pulling against a rotating magnetic field. As more power is applied, the rotor pushes harder. The magnetic field distorts and stretches slightly and the angle changes slightly.
If you were to make an index mark to show the position of a generator rotor in relation to the stator you may be able to observe the shift with a strobe light. Triggering the strobe light at the correct time is a solvable problem.
Bill
"Why not the best?"
Jimmy Carter
If you want to analyze this more formally, the angle will be proportional to the arcsin of the torque, and at constant speed, to the power.
Curt Wilson
Delta Tau Data Systems
Think of it this way. In the explanations given above, the assumption was that the generator in question didn't have the ability to overpower the grid and speed it up (increase its frequency) - massive grid, small generator by comparison. Now, assume that the generator is more massive than the grid (small islanded system, large generator). I this case, if you add enough torque via the driver, you can increase the speed (frequency) of the grid and you can increase it until you run out of the driver's ability to add torque. Islanded generators, however run on a different control scheme than generators hooked to a large grid. Those here more skilled than I will have to explain that.
rmw
One of several paralleled generators may be in isochronous mode with the others in droop mode..
A single islanded set may run in droop mode or isochronous mode.
Droop mode is very similar to proportional control plus offset with about 3% proportional band.
Isochronous is similar to proportional plus offset plus reset, or proportional plus offset plus integral. PI of a PID controller.
If you are not familiar with these control terms, try searching this site. Search also for "governors".
Bill
"Why not the best?"
Jimmy Carter
