Force imparted on pins form shrinkage
Hi, I am a little stumped one trying to calculate the force acting on three pins which are in an aluminium die casting mold.
basicly I want to work out what force is acting on these pins due to the shrinkage of the molded component material IE aluminium 1.3% shrinkage about pin PCD cenrer point, is there a reasnobly simple way to calculate the force imparted from the shrinkage onto the pins?
Any help is much appriciated.
RE: Force imparted on pins form shrinkage
htt
This link is less scary and has some calculators:
http://ww
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Your solution will only be as good as the material properties data that you use. You might find some interesting titles at this website:
http://www
