Where to source unidirectional laminate
Can anyone suggest a source for pre-made thin unidirectional/0 degree carbon fiber laminate sheeting with a thickness range of 0.1mm to 0.3mm?
RE: Where to source unidirectional laminate
http://www.dragonplate.com/ecart/
It will be difficult to find unidirectional because that is so fragile and prone to splitting. Unless you mean uncured material, which is called prepreg. Lots of manufacturers. It is not easy to get small quantities, though.
