Hardware Lock for 2003
After a re-install of my STAAD 2003 it does not recognize the hardware lock (Parrallel Port). In the past I had solved the problem by dowloding the latest HASP4 drivers from "Aladin" but it did not work this time. Obviously, talking to Bentley is not an option. I only use the program once or twice per year if that, and I hate to spend all this money for a new licence.
Any help will be appreciated
RE: Hardware Lock for 2003
It worked in the past but when I re-installed Windows XP now I lost it. I have to check the PCI card, LPT port etc. This card was added a year ago just for STAAD but I dont have the drivers and it may well be the problem.
This will usually allow you to see what types of devices are connected to your computer. If the device is not showing up, then it could be an issue with the port.
If it shows up with an error message saying that it is "not recognized" or "not operating properly" then it is likely a driver issue.
Caveat: I have never tried this with one of those ancient parallel port drivers.... It's been a long time since any of my computers even had a parallel port. :)
