High Axial Vibration at Permanent Magnetic Generator Ball Bearing
Hi guyz,..
I have problem with pemanent magnetic generator.
Our sistem is turbine (5500RPM)- Gearbox(output-1500RPM)-Generator-Exciter-Permanent Magnetic Generator.
Axial vibration at PMG is about 3-5 times radial direction (dominant at 1XRPM high speed gearbox=5500), PMG rotate at 1500RPM, with spectrum attached. we have replace the bearing and the is not any bearing cocked and nothing change in the amplitude.
is there anyone could help me...?
RE: High Axial Vibration at Permanent Magnetic Generator Ball Bearing
several days ago overall trending was about 5 mm/s (p-p)
Thank You in advance
zbiring
Cheers
Greg Locock
I dont have the software license so I make an excel plot.
any suggestion greg..?
Thank You
thanks
