Induction motor axial misalignment forces
How can one estimate the amount of axial force generated in relation to axial misalignment of rotor to stator?  This is for a 1200Hp 2 pole squirrel cage induction motor.  Is the raltionship linear or the square of the amount of misalignment?
RE: Induction motor axial misalignment forces
EASA has a good tech note on the subject.  The axial centering force is relatively small.. one or two hundred pounds... generally smaller for 2-pole motors than slower motors because the 2-pole motor rotors have no vent ducts.
Also if you want to check the force for a specific motor, you can push the rotor axially while running unloaded IF you feel you can SAFELY do so (not something to be undertaken without careful planning and thought about safety aspects).
I appreciate your input electricpete.....Theis motor is a submerged pump motor and therefore measuring the force is not possible.  Do you have a link to the EASA article?
Thanks.....
I actually  misstated the reason why 2-pole motors tend to have lower axial centering force....I think it has more to do with the airgap dimensions which tend to be smaller for 2-pole motor.
The effect of vent ducts is generally to decrease magnetic centering force (can also create two magnetic centers).
Table 1 of EASA Tech note 15-4 lists calculated restoring force in pounds for 2-pole motors with no vent ducts. First columsn gives horsepower...2nd column is force when 0.05" off-center, 3rd column when 0.1" offcenter, 4th when 0.15" offcenter, 5th when 0.2" offcenter:
HP .05 .1 .15 .2  Restoring Force in Lbs
300 24 42 54 62
500 25 44 56 64
700 25 44 57 65
1000 31 55 73 85
1750 34 62 82 96
You can see even for the largest size moved 0.2 inches off center the restoring force is only 96 pounds.
Correction in bold
I actually  misstated the reason why 2-pole motors tend to have lower axial centering force....I think it has more to do with the core dimensions which tend to be smaller for 2-pole motor.
The EASA paper is copyrighted - can be ordered as www.easa.com
There is also an IEEE paper ... available to members of IEEE IAS for free... also available to others depending on your subscription:
http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=4199057
Great information!  Our pumps have a hydraulic shaft centering feature which would act against the weight of the rotor shaft (verticly mounted axis), which if probably about 2000 lbs with all the impellers and such.  So the affect of 100 additional lbs one way or the other probably would not misalign the impellers too much to get into trouble.
I've never been able to gather much A-B-A type testing info. About the only affect I felt could attribute to the dreaded off mag center operation is a tendency to hunt axially, or bounce off the rubber biscuit in limited end float couplings, probably in combination with being  installed slightly out of level ( tipped).
