Galvanic Action between SS and Ti
I need some information on the galvanic action potential between stainless and titanium. If I have passivated 316 stainless and 6Al4VTi in direct contact in a humid (and potentially salty) environment, what risk do I have of corrosion?
Some sources I have read put SS and Ti on almost opposite ends of the galvanic table, but others have put them closer together. I understand that in order for galvanic corrosion to occur an electrolyte needs to exist. Can salty humid air act as the electrolyte, or does it need to condense before there is any risk of corrosion.
Thanks for the help!
RE: Galvanic Action between SS and Ti
If you used a super-austenitic or super-duplex SS it would hold up fine.
Plymouth Tube
What about anodized aluminum to titanium? Is galvanic corrosion then the main issue?
Here is a start.
http:
rmw
Plymouth Tube
have a look at this mil standard where there is also a galvanic chart for atmospheric exposure:
http://www.wbdg.org/ccb/FEDMIL/std889b.pdf
S
Corrosion & Rust Prevention Control
