Toolbox Missing ANSI Flange Bolts?
Hello all,
We just got toolbox installed for our SW2009 and I can not locate the ANSI Inch Hex Flange Bolts. I only see them in Metric ANSI, DIN, and ISO. DOes anyone else have the ANSI Inch for them?
BB
BB
RE: Toolbox Missing ANSI Flange Bolts?
I don't have time to dig much deeper, and others here would have a better idea of if a ANSI inch hex flange exists or not. And I don't use SW, so that's all the help I can be. (I used to use it, and wish I did, hence being at this forum topic)
-- MechEng2005
You can always make your own and make it into a Toolbox part. You just have to use the utility that comes with Toolbox to make it a fastener. Of course you can't add it to the DB like the other files are.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
