R.F. REMOTE CONTROL 2 WAY RELAYS
HI,
CAN ANYONE TELL ME IF A LOW VOLTAGE D.C. 2 WAY RELAY RECIEVER EXISTS?
I HAVE ONLY BEEN ABLE TO FIND ONES WITH AN IMPUT VOLTAGE OF 9-12 VOLTS.
I AM TRYING TO CONTROL A REVERSABLE 3.6 VOLT D.C. GEARMOTOR
AND WISH TO USE THE SAME 3.6 VOLT BATTERY TO POWER RECIEVR/RELAYS/MOTOR ETC.
THANKS IN ADVANCE.
THANKS IN ADVANCE.
RE: R.F. REMOTE CONTROL 2 WAY RELAYS
Dan - Owner
http://www.Hi-TecDesigns.com
As noted in one of the responses the EMI and RFI should be considered however I have not had any issues.
A good company to work with is Karin/NewSpirit. If there is an interest please Email me and I will forward the contact information to you. NewSpirit offers 27 MHZ, 49 MHZ and 2.4 MHZ versions and all have performed for me.
There are other companies I have worked on RF remote control however your low voltage requirement eliminated them unless you could integrate a DC-DC voltage regulator (buck/boost) into your design.
Best regards,
Bob (Email: bmorle1@hallmark.com)
Roy
