Press a bar into liquid
My model consists of a bar (0.1mm thick, 0.5mm wide) attached to a top plate. This bar is initially placed on top of liquid gel (0.3mm thick), then pressed 0.1mm down into the gel at a speed of 0.1mm/s. Is it possible to simulate the flow pattern of the liquid gel using SW flow simulation?
Thanks for help.
