grounded neutral single end
Quick question, If i run 3 single phase cables each with a 1/3rd concentric neutral, and use single end grounding.  Is there a general maximum distance a run should be before grounding the next section?  Our cable schedule shows about an average of 1000' each section.  We run a 12.46kv and a 4160v system.
Thanks for any help
