Madison Wisconsin Ground Snow Load in 1960
What would have been the design ground snow load in Madison, WI in 1960? For the purpose of agricultural timber truss design, was the method similar to today or was there a standard design roof snow load that was used? I believe the Wisconsin Administrative Code would have governed at this time.
RE: Madison Wisconsin Ground Snow Load in 1960
You may want to check the old DLIHR codes this this agency controlled everything (labor, industry, human relations and regulations)for many years before it was finally streamlined/dissected and become more open and usable. This information of the standards for designing and building in 1960. They may not have flexed their muscles then, but there may be something in the administrative files. - Agricultural buildings (depending on the current use intended)frequently were exempt from any code.
Wisconsin, under DILHR rarely adopted any code without local or specialized requirements and re-wrote/redefined some ASTM standards and structural codes.
Engineer and international traveler interested in construction techniques, problems and proper design.
