Level bridle design on 450# steam drum
I need some clarification regarding requirements on level bridle isolation valves.
ASME Section 1 Steam Drum
My current configuration has double isolation between the drum and water column. One valve is a quarter turn ball valve and the other is a gate valve. The ball valve was added two or three years after original construction. I don't have much info on this valve.
I've always used gate valves for this purpose and globes for blowdown. Does this ball valve meet code?
RE: Level bridle design on 450# steam drum
