historical Colmonoy cooling process - asbestos use?
I am looking into the industrial process associated with annealing pump plungers. I would like to know how these materials were cooled -- quickly or slowly? In a vat of flame retardants (like asbestos)? Or a "tundle" (?) in which they might cool to room temperature? Or in a "tundle" associated with an air hose?
I would be appreciative of any information.
RE: historical Colmonoy cooling process - asbestos use?
We probably used one or all these methods.
Cooled in a closed furnace. The furnace had to have a high thermal mass to retard the cooling or the temperature could be ramped down.
After welding or brazing cooled by covering with slacked lime or vermiculite.
Wrapped in "A" cloth.
The last I remember seeing slow cooled Cerawool Ceramic fiber was used.
I don't every remember using any fibers. especially asbestos.
>The parts were always cooled to RT
Can you estimate how much time this might take for a pump plunger?
Do you recall if these furnaces were lined with an asbestos refractory material? Or if they were perhaps made of an asbestos-cement mixture?
What is A Cloth?
The actual furnace lining was Hi-Temper Brick backed by insulating brick. Originally these furnaces had asbestos listing, rope, and asbestos paper incorporated as part of the lining. We went to Ceramic Wool on most furnaes and one with monolithic high Alumina lining.
"A" cloth is Asbestos cloth or lagging generally made from long fiber asbestos. The long fiber was not very friable.
Most everyone followed all the government directives from different branches.
I really value your input - thank you so much!
