Element type & attributes
Hey,
I am making some surfaces from points > curves and then surface by taking {edge curve}. Whenever I try to assign any property it goes to solid element. I am creating surfaces and I do not know why it is going in solids. Any recommendation or suggessions ? ....
RE: Element type & attributes
Which preprocessor are you using?
We can't help you if you don't specify the preprocessor.
Actually, while modeling in FEMAP 9.3.1 I am getting this problem.
So post your request in the Femap forum.
