assembly cut
assembly cut
assembly cut
I made a extruded aluminum assembly and went back and made some assembly cuts.  After I made the cuts there are blue surfaces.  See pics. not sure who to explain what Im getting.  How do I get rid or not show them?
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: assembly cut
wish it was that easy.  I already checked, there are no colors assigned at the part or assembly level.  There are no "blue surfaces" if I roll back or suppress the assembly cuts.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: assembly cut
It's the way it was set up.  Not going to redo it for this project.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: assembly cut
where are the assy cuts?
RE: assembly cut
"where are the assy cuts?" In the assembly?
I converted entities of the extrusions tangent edges to get my cutting plane.  So the cutting plane is on the same plane as the exterior face of the extrusion.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: assembly cut
Maybe this is a "display shaded planes" thing - look in Options - Display/Selection and see if "display shaded planes" is on
RE: assembly cut
No go.  Unchecked it and there still there.  It's not a big deal, zoomed out you can't see them.  Just not sure where it is coming from.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
