Curvature Matching in NX Cam
Hi all,
I'be been trying to find information on the Curvature Matching module in NX, NX30407.
The pricebook gives a brief explanantion of what it is but it's not too clear.
What advantages does it give over standard multi-axis modules and how does it work?
Thanks in advance
Speedee
RE: Curvature Matching in NX Cam
I would recommend contacting your customer service rep or GTAC.  They could explain it and maybe give you a temp license to try it out for a while.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6, 7 Solid Works, Solid Edge
Imagine cutting a curved surface with a flat end mill. The system will tilt the tool axis forward, raising the trailing cutting edge, to match the curvature of the part. On a flat or convex surface, the tool would be normal to the part, or you may tilt it forward a couple degrees. But in concave areas, the tool axis tilts further to match the surface.
With this, you can use a much larger stepover than a ball mill, and get a much better finish, since the scallops are almost flat.
To learn more, search for "Optimized to Drive" in the Variable Axis Surface Cointouring help, or request a trial license.
Mark Rief
Product Manager
Siemens PLM
Thanks Guys,
sounds useful, I'll get it added to my license.
Speedee
