Curing tank issue
Curing tank issue
I have come across a new problem that I have not seen before. We are getting a thin film over the top of the water surface in our curing tanks. The film is sort of off-white/translucent, and is like a thin crust.
The one tank had been used for holding buckets for sodium sulfate durability testing, and I am sure some of the solution had dripped into it. The water was removed, and the tank "cleaned" and resealed with roofing compound at the seams. After lime was added to the tank, the surface film started to form.
Has anyone seen this? Do we have a reaction between materials, bad lime, etc.? Any way to salvage?
RE: Curing tank issue
I have no issues taking some out, but we put it in (at least I calculated it) to the standard.
It's a bit odd that you have a surface encrustation. There might be some other factors working here. Usually when there's just too much lime, it precipitates and settles out.
Wild guess - Could the lime be reacting with some of the minerals in the water? lime plus hard water could form calcium carbonate.
