Arc Flash Calculations - Phase or Ground Settings
Hey guys. Do the IEEE arc flash calculations utilize phase or ground fault settings?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Arc Flash Calculations - Phase or Ground Settings
The NESC data for overhead systems is based on line-to-ground faults calculated using ArcPro.
David Castor
www.cvoes.com
