Wireframe text in NX6
Experienced NX I-Deas user new to UGNX6 would like to know if anyone has been able to create single line wireframe fonts in NX. The text command always makes the text fat. I just want single line text to be able to scribe this on a steel plate.
RE: Wireframe text in NX6
Now if you really need single line text as geometry, that can be done by creating your note, exporting it as a CGM file and then importing it back into NX and curves. Perhaps a bit crude, but something that has worked for many people over the years.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
It is just that in I-Deas the wireframe text command is so simple. Works just like the text command in NX just that you can have simple line text as well as fat double line text.
I will take a look at the CGM option.
Jurgen Kreisel
John
If you do want "Curves" that are stick figures then use Modern Font. See the atached file.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6, 7 Solid Works, Solid Edge
That's exactly what I was looking for, even GTAC did not know how or which font to use. I thought I went thru each of the fonts but I guess I missed this one.
Jurgen
John
