White Decals look gray in drawings
As the title states I'm having a problem where I will put a decal on a face in the part file and any white in it will end up looking gray in the drawing.  I have messed around with the illumination settings for the image and nothing seems to work out.  If anyone has any input I'd greatly appreciate it.  I'm on SolidWorks 2009 SP5.0   Thanks
RE: White Decals look gray in drawings
serspec,
I have had the same problem as you when using decals.
My best advice is to not mess around with the lighting settings under the 'decal' section. That affects the rendered images which aren't used in the drawings. You need to change the 'standard' (non photoworks) display settings.
Go to the Lighting Folder on the feature tree for the part.
Bump up those lighting settings and it should lighten the entire part, including decals.
Obviously this affects the color of the entire part as well as the decal, which may or may not be an issue.
Hope this helps.
Worked out great thanks alot!!  Was able to offset the other objects being too bright by adjusting the settings for those materials separately.  Thanks again for the input.
Switching to a different scene (Apply scene icon in the heads-up toolbar) also affects the lighting and colour of parts.
