Help Identify ITT 3 way Valve
Okay, I'm wondering if anyone has any ideas.
Exhibit A, shall we say, is a 3 way actuated valve, with an ITT tag, I would say of European descent. We have contacted ITT Engineered Valves directly, and nobody there recognizes it.
With the history of ITT, I'm guessing this was a valve product line that was sold off to someone else (much as the old ITT-AC butterfly valves were sold to Rodney Hunt). It's also possible that it's someone else's valve that was simply nameplated by ITT for a special job.
But I'm stumped at this point - does anyone recognize that valve, and have an idea of who owns the product now? Sometimes, experienced eyes looking at an old item can recognize it.
The tag calls it a PSVD 65/63.
RE: Help Identify ITT 3 way Valve
For what purpose do you need the information? Repair or replacement? Other?
Identifying of older valves with unreadable tags or signs, and no other information than what you physically can see from outside is unfortunately a common problem.
We usually (as a supplier) try to solve this problem by trying to get answers on a number of questions, - and to get the best result it has to be this many:
How old is the valve?
When was it installed (guess?) and type and intensity of use?
Does it perform as expected?
If not, is the actuator OK?
If yes, what type of performance fault?
Any visual outside damage?
Any visual outside markings?
(By the way your ND16 could be German casting mark for 'Nenndruck DIN PN16', eg flange measurements equal to modern pressure class European EN PN16, but not necessarily at a standard building length for the valve - try German ITT sources for further identifying, or see the Clorius range below)
All relevant outside measurements, building length, flange measurements, topfalnge measurements, including for all flanges bolt circle diameter, bolthole diameter, number of bolts, flange thickness, measurement if uneven distribution of bolts, spindel top form with all outer measurements etc.
All necessary data about process, expected performance, fluid and other relevant information dimensioning a new valve.
Has the valve been opened?
If not, can it be done and visually inspected inside?
All this mentioned, because very often a repair of an older valve, and/or trying to repair a valve and keep an existing actuator for the valve running is costly and complicated, and will not give a very long expected lifetime.
A repair should normally be compared to what the market can offer regarding a complete new valve and actuator with performance (sizing) controlled according to todays data.
A repair for refurbishing a valve with original spares is to be recommended, but in cases it could be very costly, time-consuming or almost impossible. In this case a local repair by a good experienced valve-service company could be a better solution.
For your special valve: have a look at the European Clorius range (Denmark - but internationally exported)
http://
