Contact Mechanics
Contact Mechanics
Hello all,
I would like to clarify something about the the stress distribution of contact between two bodies. I have seen many references show the maximum shear stress (Tmax) to be below the contact surface. e.g. seem the image shown in wiki below
http://en.wikipedia.org/wiki/Contact_(mechanics)
However, the contact pressure and maximum normal stress is maximum at the surface, and my FE analysis also shows the maximum stress to be at the surface of contact. Can anyone provide some further explanations on this.
RE: Contact Mechanics
Cheers
Greg Locock
Thanks for your feeback, I am not getting confused between the two, I just don't think I have explained my questions clearly enough.
My original question in another way is:
I am looking for an explanation of why shear stress is maximum at a point below the surface. Any theories, equations to explain why.
Greg's suggestion is that you get a copy of Timoshenko's Theory of Elasticity and study it.
I can give you a trite answer that the boundary condition at the point of contact is a normal force, therefore there can be no shear stress at that point, and the maximum shear must then occur somewhere else.
But that doesn't really fully explain it.
I have a strong feeling that Timoshenko is clearer than the above handwavy description!
Cheers
Greg Locock
http:
The guy that formulated the theory behind contacts between elastic bodies was not the Irishman Tim O'Shenko, it was the German Herr Ztian.
Technically, OptiEng is correct. The absolute max stress in his two contacting bodies is at the surface. But most materials will fail due to sub-surface shear fatigue long before they fail due to surface bearing. The classic contact failure mode is a sub-surface shear initiated fracture that propagates up through the case and creates a surface spall.
riff raff
Cheers
Greg Locock
But i wonder if they actually answer the OP's question? My gut feeling is that there is a natural wedge angle for a material.
This turns normal forces into shear.
Slightly silly question, if you model this with an element size of the order of 0.02r, does it show the same sort of effect?
Cheers
Greg Locock
Well, ACTUALLY...Herr Ztian figured out the maximum stresses, but the guy who figgered out the equations for the max shear stress (ocurring below surface) for contact problems, Belajef it or not...was some kinda Eastern European, always in trouble for Rushin' around or something. Tim O'Shenko, between bouts of drinking and dart throwing at the pub, cites that work in the reference given earlier, which is probably a good thing, because Irish is easier to puzzle out than Russian.
Thanks for all your input, its very useful. Great discussion too. With a bit more digging I also found that Shigley gives a nice summary of cylinder or sphere contact but doesnt really answer the question of normal and shear stress states. Ione's upload is useful though.
Thanks again.
OptiEng
I suspect if you plot stress intensity or von Mises stress in your FE model you would see that it is maximum below the surface.
OptiEng
As already pointed out above (tbuelna) a critical section is located at a certain distance from the surface and the maximum shear stress is responsible for the surface fatigue failure.
