Save Bodies - with reference surfaces
I have a master part file with surfaces (cutting & reference) that I can use to split the solid to form multiple solids.
I right click the solids folder to choose save bodies. I choose a location to save.
My question :
When I open the automatically created part file, I want to have all the other reference surfaces, sketches, Planes etc that were present in the master model.
I want avoid inserting the master model into the part file. Its like inserting a parent into the child feature.
Any suggestions.
BT
~ BT
RE: Save Bodies - with reference surfaces
No there is no option/method to do that. The best way will be be either make 2 configurations in the part itself and suppress delete body in one, keeping the second one and vice versa for second configuration or with the same scenario you may create 2 copies of part. You may add LH & RH to the config or part name.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
