Non-pressure Welds to Section VIII Div I Vessel
Hello:
Eventhough I have benefitted a lot from reading the various posts, this is my first one. Hopefully not a repeat post.
We have a water seal drum which is designed to ASME Section VIII Div I but not code stamped. Is it possible to weld non-pressure attachments to it without having to hydrotest it again.
Also, what determines when a vessel has to be stress relieved.
RE: Non-pressure Welds to Section VIII Div I Vessel
Yes. This would be an in-service weld repair.
Base material thickness and chemical composition.
For your stress relief question, do you mean Post Weld Heat Treatment? The two are often mis-used. PWHT requirements will be spelled out in the sub-section for which the material of construction is found (i.e. Carbon steel vessels fall under part UCS. UCS-56 dictates PWHT requirements).
My thoughts are this: If the vessel is not code stamped, it should be agreed upon by the end user and the manufacturer if the vessel should be re-hydroed.
That being said, you need to be sure and comply with local jurisdictions and contact your local AI to see if they require any specific testing. Also make sure that the attachment is truly non load bearing.
The National Board Inspection Code-Part 3-S4.18.2.6 - Type 5 - Miscellaneous General External Repairs or Alterations, states that external repairs or alterations on non-pressure parts shall be "calculated" to the original code of construction, and reviewed by the AI and a P.E., but it does not require a pressure test.
However, if you ask what can be done in order safely and properly to weld - that's another question.
On a side note, please disregard my previous reference to particular NB spec, that was an incorrect paragraph reference.
Incorrect. The NBIC, Part 3 Repairs and Alterations allows alternative weld repair methods in lieu of PWHT.
If the shell was 2" thick SA516-70 and PWHT for code reasons only, would adding a 3/8" ladder clip with a double 3/8" fillet require PWHT? Unless I'm mistaken, that particular weld would not require PWHT per Div. 1.
jt
You are correct, no PWHT would be required for the attachment welds.
Can you please direct me to relevant section of Code (ASME-VIII-1) which says that PWHT will not be required for the attachment welds?
Starrproe
In Section VIII, Div 1 look at Part UCS, UCS-56 for P-No 1 material. Review the definition of nominal thickness.
In addition to reviewing the definition of nominal thickness as it pertains to weldments, review Table UCS-56 Note (2)(c)(3). In my example above, provided a preheat is provided on the shell the fillet welds could have been 5/8" and still had a throat thickness less than 0.50" so no PWHT would be required for that weld.
It's sometimes useful to remember that we PWHT individual welds, not vessels. For convenience we sometimes place the entire vessel in the oven, but that is not a requirement.
jt
Agreed. But since the vessel is not code stamped, the end user should be at least made aware that his vessel is going to have parts welded on to it after final hydrotest.
