pro mechanica license problem
Hello everyone,
I was using Pro Mechanica yesterday and it was working fine and then I started getting an error message that said "The license to run the engine is not available" This started after I created a new material and saved ini the material library. I am perplexed? Any thoughts?
RE: pro mechanica license problem
Let us know if this sheds light on the situation or causes more questions.
Steve
Try issuing the ping command from the command prompt. Ping the license server name and see if any of the packets have an extreme delay or worse...get lost during the ping test.
Sorry I couldn't have been more help.
Steve
